engine build
engine build
So it starts....
1914cc, dual Weber IDFs
Case was decked, opened for 94mm cylinders, tapped for full flow, rods and pistons were balanced. Crank is 69mm CW forged 8 dowel with a forged and lightened flywheel.
More to follow.
Re: engine build
Whats this going in? Or who's it for?
Re: engine build
Going in a Ghia.
It's not for me.
Re: engine build
It's a short block. Measured the deck height and ordered new Panchito heads from CB.
The CB H-Beam are awesome. I really like them.. very high quality.
All new hardware and its a pleasure to have new chromoly head studs.... fresh clean threads.
Re: engine build
Perhaps you should be looking into building a type four engine since so many people seem to be having issues.
Re: engine build
EDNCAROL wrote:Perhaps you should be looking into building a type four engine since so many people seem to be having issues.
Sorry, but i like Type 1s.
Re: engine build
yummy!
Re: engine build
Flywheel and pressure plate is on. Endplay is .003" and torqued to 325ft-lbs.
Forgot to show the 1.5qt deep sump.
I ordered the heads yesterday. CB Panchito 044 40x35 with dual springs. CR will be 8.5:1.
Now I have to wait for the heads to arrive.
Re: engine build
pretty :D
Re: engine build
BusBq Bill wrote:pretty :D
Wait... tins are powder painted Porsche Guards Red and it has a red serp belt.
Re: engine build
Re: engine build
Does AOT know about the red serpent belt ?
Re: engine build
All the tin is bright red.
Re: engine build
shiny
Re: engine build
Glenn wrote:Image
That's one hot mama!!
Re: engine build
Almost done.
Re: engine build
looking bad ass. Glenn is there a reason why you didnt go with a 76 crank
Re: engine build
elrockk wrote:looking bad ass. Glenn is there a reason why you didnt go with a 76 crank
76 can be tricky with rod length and pin height. A 94x69 is a pretty proven combo and using A pistons and 5.4" rods.
I ran into enough issues with only .012" endplay with NO shims. i had to have the nose of the flywheel trimmed .020". Then the rocker arms are not in the correct location over the valve stems. I had to have the rocker arm pedestals machined so I could shim them to get the geometry correct.
Gotta over aftermarket parts.
Re: engine build
The anodized pulleys actually dont look that bad. Generally the color is way off........
Can we talk about the lower cyl head tin on the 1/2 side? Going with a ' match the cap/ rotor color ' are we? haha
Nice looking motor... great work
Re: engine build
It'll run faster with a clear cap.
Re: engine build
MrBreeze wrote:It'll run faster with a clear cap.
Re: engine build
i see so just because you can doesnt mean you should
Re: engine build
My personal engine is a 2180 (92x82) and was done with my money and no deadline.
Re: engine build
i was hoping to build something larger then 2 litre with an after market case but the funds arent coming thru to finance that so for now its 1600 efi turbo in the future
Re: engine build
My 2180 has a VW case.
Aftermarket = more work.
