Posts: 3215 Joined: Tue Sep 09, 2008 4:20 pm
Post
by Glenn » Fri Oct 06, 2017 5:30 pm
So it starts....
1914cc, dual Weber IDFs
Case was decked, opened for 94mm cylinders, tapped for full flow, rods and pistons were balanced. Crank is 69mm CW forged 8 dowel with a forged and lightened flywheel.
More to follow.
Posts: 1937 Joined: Tue Sep 09, 2008 8:03 pm
Post
by Raj » Mon Oct 09, 2017 7:40 am
Whats this going in? Or who's it for?
Glenn wrote: I have to say, this "gruppe" is so much more than just a car club.
MrBreeze wrote:
This is the DVG board. The threads flow as they flow.
Post
by Glenn » Mon Oct 09, 2017 5:53 pm
Going in a Ghia.
It's not for me.
Post
by Glenn » Tue Oct 10, 2017 6:03 pm
It's a short block. Measured the deck height and ordered new Panchito heads from CB.
The CB H-Beam are awesome. I really like them.. very high quality.
All new hardware and its a pleasure to have new chromoly head studs.... fresh clean threads.
Posts: 763 Joined: Wed Oct 01, 2008 12:25 pm
Post
by EDNCAROL » Tue Oct 10, 2017 6:18 pm
Perhaps you should be looking into building a type four engine since so many people seem to be having issues.
Post
by Glenn » Tue Oct 10, 2017 6:40 pm
EDNCAROL wrote: Perhaps you should be looking into building a type four engine since so many people seem to be having issues.
Sorry, but i like Type 1s.
Post
by Raj » Wed Oct 11, 2017 6:59 am
yummy!
Post
by Glenn » Wed Oct 11, 2017 12:16 pm
Flywheel and pressure plate is on. Endplay is .003" and torqued to 325ft-lbs.
Forgot to show the 1.5qt deep sump.
I ordered the heads yesterday. CB Panchito 044 40x35 with dual springs. CR will be 8.5:1.
Now I have to wait for the heads to arrive.
Posts: 311 Joined: Thu Jul 09, 2009 9:33 pm
Post
by BusBq Bill » Wed Oct 11, 2017 4:30 pm
pretty
Post
by Glenn » Wed Oct 11, 2017 4:33 pm
BusBq Bill wrote: pretty
Wait... tins are powder painted Porsche Guards Red and it has a red serp belt.
Post
by Glenn » Fri Oct 20, 2017 5:27 pm
Posts: 1050 Joined: Sun Sep 14, 2008 12:02 pm
Post
by Tom » Fri Oct 20, 2017 6:40 pm
Does AOT know about the red serpent belt ?
Brown wrote: Tom is right!
Post
by Glenn » Fri Oct 20, 2017 8:31 pm
All the tin is bright red.
Post
by BusBq Bill » Fri Oct 20, 2017 10:36 pm
shiny
Posts: 1029 Joined: Fri Oct 17, 2008 8:09 pm
Post
by AoT » Fri Oct 20, 2017 10:43 pm
Glenn wrote:
That's one hot mama!!
Post
by Glenn » Tue Oct 31, 2017 6:29 pm
Almost done.
Posts: 396 Joined: Mon Jun 01, 2015 6:26 pm
Post
by elrockk » Tue Oct 31, 2017 8:13 pm
looking bad ass. Glenn is there a reason why you didnt go with a 76 crank
Post
by Glenn » Tue Oct 31, 2017 8:46 pm
elrockk wrote: looking bad ass. Glenn is there a reason why you didnt go with a 76 crank
76 can be tricky with rod length and pin height. A 94x69 is a pretty proven combo and using A pistons and 5.4" rods.
I ran into enough issues with only .012" endplay with NO shims. i had to have the nose of the flywheel trimmed .020". Then the rocker arms are not in the correct location over the valve stems. I had to have the rocker arm pedestals machined so I could shim them to get the geometry correct.
Gotta over aftermarket parts.
Post
by Raj » Wed Nov 01, 2017 7:07 am
The anodized pulleys actually dont look that bad. Generally the color is way off........
Can we talk about the lower cyl head tin on the 1/2 side? Going with a ' match the cap/ rotor color ' are we? haha
Nice looking motor... great work
Posts: 1865 Joined: Tue Sep 09, 2008 8:21 pm
Post
by MrBreeze » Wed Nov 01, 2017 7:18 am
It'll run faster with a clear cap.
Post
by Glenn » Wed Nov 01, 2017 8:13 am
MrBreeze wrote: It'll run faster with a clear cap.
Post
by elrockk » Wed Nov 01, 2017 10:47 am
i see so just because you can doesnt mean you should
Post
by Glenn » Wed Nov 01, 2017 11:27 am
My personal engine is a 2180 (92x82) and was done with my money and no deadline.
Post
by elrockk » Wed Nov 01, 2017 7:10 pm
i was hoping to build something larger then 2 litre with an after market case but the funds arent coming thru to finance that so for now its 1600 efi turbo in the future
Post
by Glenn » Wed Nov 01, 2017 7:14 pm
My 2180 has a VW case.
Aftermarket = more work.
