can anyone show me or tell me the difference between Type 1,2,3,4 engines im gonna look at a shortblock that the seller says may have a universal case so wont have the letter markings to id
Type 1 is a upright engine used in Beetle, Ghias and Things. Type 3 are the same as a Type 1 but have a fan in the rear.. they're Pancake. A Type 4 is a pancake but a totally different case... it's a "big block".
There's no such thing as a Type 2 engine. Early Buses has Type 1 and then in 72??? they got Type 4.
so if it looks like my engine it should work?
There's a large snap ring holding the brass gear on. The cam gear is pressed on. If you heat it with a torch it will expand and come off.
I see EMPI.
