Can someone translate for me? i'm not too knowledgeable with these old suspension set ups or that a transmission has a different case depending on the electrical system voltage?
its from this ad : http://www.thesamba.com/vw/classifieds/ ... id=1710320
"Stock front beam, drop spindles up front
Swing axle kit out back. Welded 1-2 welded 3-4 388 ring and pinion. Freeway flyer. Tranny case is a stong 12v case. Not a 6 volt that has been ground out. Type 3 brakes. "
Translation Please
- First Name: MarkusK
- Vehicle Year: 1979
Translation Please
Re: Translation Please
The front beam is stock, not lowered or narrowed, but it does have dropped spindles which lowered the front.Markus wrote:Can someone translate for me? i'm not too knowledgeable with these old suspension set ups or that a transmission has a different case depending on the electrical system voltage?
Tranny is beefed up with the syncros weld to the gears and a 3.88:1 ring and pinion. Also it has a later case which is stronger.
Must be a Type 1 tranny that they put wider Type 3 rear brakes on.
Yes, they used a t1 trans with no redux boxes to lower the arse.
cool thanks, i think i get it. Looks like its sold anyway. Ad was up for less than 24 hours. no trip to north dakota for me!
Markus,
You looking for a new toy? whats the plan and what are you looking for?
mostly just day dreaming about split double cabs. But hey there was a time I was daydreaming about bay window westy and now i have one.
I should do the responsible thing and spend the money on a paint job, which i will bring up in a separate thread...
