Help me decide
Re: Help me decide
Thanks Glenn. Ur making it too easy!
Re: Help me decide
Glenn likes to spend other peoples money!!rob711 wrote:Thanks Glenn. Ur making it too easy!
Re: Help me decide
I don't mind, he's finding solutions to problems for me, now if he could just get me a link to a money tree. Just found out wife's sequoia needs a catalytic converter, between that and the hot water heater I'm sorta tapped this month. But I will grab that distributer as soon as I can.
I never met any of you,except mike for like 5 minutes, but it's cool to find a group of non douche bags into the same shit as me. Thanks
Rob
Huh? Maybe I should hold my judgement until I meet you folks in person!
Rob
Re: Help me decide
How about a "money weed"?
In Colorado the dispensaries are turning it into bags of money.
Re: Help me decide
Put that in MY pipe and smoke it!
Re: Help me decide
Didn't think it was worth starting a new thread, just an update. In-between other chores I spent some time on my bug this weekend. Replaced all gas lines, except under tank (I will get that when I replace master cylinder) installed filter over trans, new air filter and checked valves. I then drove it! Woo freaking hoo! First I kept it local, then Sunday I went from east north port to west islip, trouble free I should add. It ran great. I did get my rebuild kit for original carb, and I have the original distributer, along with tools in car. Hope to get to a show or meeting soon. Thanks for ur advice.
Rob
Rob
Re: Help me decide
Nice work Rob.
You might want to start a "build" thread for your car. Most of us have one for our cars, and it becomes a catch all for projects about your car and limits the piece-meal threads that pop up for various issues on the same car.
Yes, there will be discussion in the head, but they are discussions on upgrades and maintenance issues that you start.
My bus' thread is 30+ pages, but amidst the discussions are how-to and help for others on what I have done. Plus, it becomes a work log for you so when/of the day comes that you sell the car, you know what repairs/upgrades were done and what date they were done.
Re: Help me decide
Saw this on craigslist and thought of you!!!
carburator and distributor setup!
http://longisland.craigslist.org/pts/4398282330.html
Re: Help me decide
I usually check cl I missed that. Thanks brown! Any ideas what carb that is? I will shoot the guy a email.
Re: Help me decide
Could be a 34pict3, mine looks to have the same parts in the same places.
Re: Help me decide
So I emailed the guy, asked what carb, alt or gen fuel pump, dist vac good. This is the answer I get
"Pretty sure its a 34....not sure if its a gen or alt but u will be able to see it as its in my new engine....vac is good. Was on running engine..."
What the f? Is it on a engine? Oh craigslist! It will be hard to meet up with this guy but mayb next week I can get out there
Re: Help me decide
The alt/gen is on his new engine?
IIRC if you have a generator you can run either pump, but due to the larger alternator diameter you would need the correct pump to have adequate clearance for an alternator. You also need the correct push rod for the pump, the lengths are different.
Re: Help me decide
WhAt carb is that? I've been emailing the guy. He says he spent 5gs on new motor and trans. Switched to 1710? Empi dual carbs. Dosent know what distributer or linkage dosent know if he has generator or alt. I told him I can't get there this week. The heat risers look nicer than mine. And I don't have the vac port on left side of intake , but rear carb one works on my carb for pre heat. He says vac on dist is good. All work done by frank in Hicksville but slow as hell. He tells me.
Anyone in Baldwin?
Rob
Anyone in Baldwin?
Rob
