Ethanol safe braided fuel line
Here's a stock looking cloth braided hose, made in Germany that is E85 safe.
Since i was planing on replacing all my fuel line anyway I purchase some of the 6mm and some of the 8mm.
https://www.belmetric.com/multifuel-hos ... 5q4a0ee7t0
6.0mm Flennor Multi-Fuel hose. ID 6.0mm, OD 11.0mm
Approved for gasoline, diesel fuel, water, air,heating oil and withstands higher levels of Ethanol up to E85
That means this hose can handle up to 85% ethanol in gasoline. Working temperature, -25 to 250 Degrees Farenheit
Working pressure 150 PSI, DIN 73379
Re: Ethanol safe braided fuel line
So are you going to drive it this year ? Getting it inspected and fresh gas doesn't count.
EDNCAROL wrote:So are you going to drive it this year ? Getting it inspected and fresh gas doesn't count.
Well... I don't plan on towing it to the inspection station. Though I do have my tow bar back ;)
