Posts: 223 Joined: Sun Jun 14, 2009 4:00 pm
Post
by B MAN » Wed Jun 15, 2016 9:51 pm
Whats the simplest way to do this with dual carbs?
Breather box needs to be mounted in such a way that all the oil "gravity drains" back to the filler neck which on my car looks something like this
I saw a couple mounted inside the cabin on the other side of the firewall but doesn't seem like that would gravity drain very well
Post
by B MAN » Fri Jun 17, 2016 10:20 pm
nothing?
Posts: 3214 Joined: Tue Sep 09, 2008 4:20 pm
Post
by Glenn » Sat Jun 18, 2016 5:38 am
Mount the breather on the firewall above the fan shroud.
ainokea
Posts: 2 Joined: Tue Dec 08, 2015 8:26 pm
First Name: vernal
Vehicle Year: 1973
Post
by ainokea » Mon Aug 01, 2016 10:43 pm
I use the same type of fill neck except mine is straight. The breather box is mounted above the shroud and is plumbed to the fitting on the neck. Works well for me. Have a photo showing the breather set up with dual 44's but it's to big and won't load. Ainokea
