Page 1 of 1
Turning signal switch wiring
Posted: Wed Mar 18, 2015 10:40 pm
by B MAN
Trying to wire my turning signals up
according to this
i believe im looking at 'H" on there
tried tracing the wires i cant figure out these last few
which is coming off the turning signal signal harness
Re: Turning signal switch wiring
Posted: Thu Mar 19, 2015 7:22 am
what doesnt work at the moment? that will be your first clue. If its coming from the turn harness, turn on the directional and see if you have any power coming out of the wires. best tool for this job is a 'power probe' if you can get one. Look around for a correctly color coded diagram too if this isnt correct.
Posted: Thu Mar 19, 2015 8:20 am
by B MAN
I rewired the car, so I'm trying to get the turning signals for the first time
my assumption is
1- power
1- ground
1- blinker relay
1- high beam relay
just don't know which wire is which
I'm not bothering with the windshield wipers yet.
Posted: Thu Mar 19, 2015 8:49 am
by EDNCAROL
Save that job for a rainy day!
Posted: Thu Mar 19, 2015 8:53 am
by Tom
B MAN wrote:I rewired the car, so I'm trying to get the turning signals for the first time
my assumption is
1- power
1- ground
1- blinker relay
1- high beam relay
Did you buy a new harness ?
Posted: Thu Mar 19, 2015 8:58 am
by B MAN
yes from wiringwerkz or something like that but these specific wires were not replaced. they told me that before I bought it. so I've got plenty of length on all the connections... just don't know where they go
Posted: Fri Mar 20, 2015 7:48 am
by Big_kid
Looks to me like black with white is the left turn, black with yellow/green it right turn. Whitish is parking/running lights. If that's not what you have in the harness, look at what color wire goes to the light sockets and find that color wire. A volt/ohm meter is a good thing to have here, even the cheap harbor freight one will work well enough for this. Also- if you can find a small 12 volt battery you can use it for testing, but the car's battery will do. I suggest a small one because it can do less damage if something goes wrong. Also jumper wires with alligator clips are invaluable when testing wiring. You can try it out before you cut/splice/terminate that wire and make it permanent.
Print out that wiring diagram in full size, even if you have to do screen captures on 6 pages (like I did) to do it. then line them up and tape them together. I put that on a poster board, and covered the whole thing in scotch tape to protect it. I now have a huge wiring diagram of my buggy (and a 1970 beetle) with all my notes on it for next time I wire it (or something else).
BTW- I think your turn signal switch is labeled T. If I'm reading correctly, H is the hazard switch.
Posted: Fri Mar 20, 2015 11:07 am
by B MAN
the 3 brownish ones r the tricky ones
Posted: Fri Mar 20, 2015 2:39 pm
by Brown
B MAN wrote:the 3 brownish ones r the tricky ones
Brown is normally ground. Your wiring diagram shows i brown going direct to ground. The other going to the ground on the speedo and the last brown going to the horn circuit, through a plastic connector.
Posted: Fri Mar 20, 2015 7:01 pm
by Big_kid
^^ What he said. Brown is well grounded.
(sorry about the typos earlier, I had just started the first cup of coffee when I posted)
Posted: Fri Mar 20, 2015 7:36 pm
by B MAN
thank u!
Posted: Fri Mar 20, 2015 9:03 pm
by Brown
B, what year is the Ghia? The drawing you posted shows one brown to ground.
1 to the horn relay and the brown with white stripe to the dimmer relay
Posted: Fri Mar 20, 2015 9:15 pm
by B MAN
72
i wanna get working turning signals
horns n high beams :roll:
Posted: Sat Mar 21, 2015 10:18 am
by Big_kid
Take an ohm meter to the leads and start hitting switches. When you make a connection, you'll know what it is. Look at the wires in the harness. Find the wires that go to that device, and there ya go. It's only intimidating at first, and only if you let it be. You got it this far, you'll get it the rest of the way.
