Tacoma Lives
Posted: Mon May 05, 2014 11:43 am
After much throught and checking the want ads for used trucks i finnaly decied to give repairing my rusted frame a shot. Wheni last left off the truck failed insepction due to frame rot in front of the shackles, both sides.
i ended up removing the bed, gas tank and two cross membsrs to really be able to get to the problem areas. WIth the bed off i discoverd some holes in the frame above the passenger side rear tire.
I orderd some 1/8" steel plate, had a channel the size of the frame made and set out cutting out the really bad sections of the frame, welded in the new channel sections and then wlded some fish plates across the new channels to re-box in the sections of the frame on both sides that were bad. The i welded some plates tothe side and underside of hte frame above the reas tie, passenger side. It feels very solid now. Last night I prepped it for Por 15, which i will apply tonight. After it dries i have to re-installt he cross members, gas tank, rear bumber and tow bar and then take it back to the gas station for an inspection. If it passes i'm good to go. If not I get out the torch and pull a Paulie on it.
I'm hopeing to buy myslef a couple of years to be done with college payments and then i can buy something nice!!
