from what I've read on the samba, I don't even need that for the third brake light I am going to install on my bus...
I dont know what youve read, and Im certainly no expert at third brake light installation. But Id imagine if you use the power lead from the brake lights to activate the third brake light, whenever you use the directional (effectively a single-side activation of the brake light) the third brake light would also flash. Make sense in theory. Id be interested to read what others are doing.
Yes dubstar your bus will need the logic module if you want the third brake light to stay solid.. otherwise you could run a wire from the front and would not have to use a module.. but for $6.95 i think the moudule might be easier... :ugeek:
http://www.jcwhitney.com/logic-circuit- ... map=13585G
No worries... I have one on the way, don't think Im'ma need it! LOL
Got to see some more pictures from the photo shoot...
What no "action" shots?? ;)
Brown wrote:What no "action" shots?? ;)
Boots on ?
Boots on ?
lol... i just though the same thing!
Theyre very hipsterish (I guess is the way to describe them?) But very cool to talk to, nice couple. The pics came out awesome. Cant wait to see the final ones!
Boots on ?
Check the headliner for smudge prints in the shape of a boot sole.
Im assuming since the Thing uses the same diameter and style headlights as the baywindows that the trim rings are interchangeable. That brings me to ask, does anyone have or know where I can find, a set of thing headlight grilles? I think they might look kinda cool/mad maxx-ish on the bus. Esp with my kick-ass roo's!
Are you looking for the wire screens that go over the headlights? They are aftermarket baja style items, not 181.
aftermarket anything... for 7" Headlights.
http://cgi.ebay.com/Pair-7-Headlight-St ... 335ddf48be
I wonder if empi makes them?
SPOTLESS even after 18 inches of snow! Man do I love a clean bus :-)
Anyone have leads on where I might obtain an ECU (The computer/brains) for the bus? Having some FI issues, and just want to know where I can find one, before being told I need to go hunt one down.
ObnoxiousBlue wrote:Anyone have leads on where I might obtain an ECU (The computer/brains) for the bus?
http://www.thesamba.com/vw/classifieds/ ... ds=bus+ecu
at what point does it become worth it to convert to carbs? I assume at the end of the day - they are more reliable?
gotboost79 wrote:at what point does it become worth it to convert to carbs? I assume at the end of the day - they are more reliable?
Unless it's a total system failure, FI is better than carbs on a Bay.
mike, is that a bosch unit? if so, my '77 has a wiring harness that partially connects to the battery...I had some problems that were directly related to loose and dirty connections there...check and clean, as it may be a simple fix
ECU from a '79 work?
I agree with glenn, the L-Jetronic fuel injection on a type 4 is very reliable if maintained like any other engine.
How's Peabody doing? Will he or she? make it to etown?
On the road again...
Was it the ECU ?
