my project 71
does anyone have a junk dual port engine i could have or borrow? i need to mock up/fabricate an intake manifold for my fuel injection project
12 feet of 2 inch aluminum for intake/turbo tubing Image
i had to grind some tabs off the injectors and hand sand the injector bodies to get them to fit Image Image came out nice Image Image Image
Coming along nicely. Keep at it !
very excited to see the outcome on this....!
got some AN#6 fittings and cut the step off the inside Image Image Image Image tried to cut off the fuel injector cups from the fuel rails i have and relocate them but that was a mess so time for plan B
Keep at it- the world is watching and learning.
heres plan B I had some high pressure fuel lines in my junk pile Image cut the ends off and brought them to work and drilled the threads out to 14mm Image the one on the left is the thin factory one way to thin for me to weld the new ones are beefy Image and here is a mock up of what im shooting for Image.im gonna ask a friend weld it up so it comes out nice
got my intake flanges roughed out Image now just need to sand them to the mark and find my e saw set
Keep at it, it's motivating seeing others making progress on their projects too.
had some time today so i made wooden intake flange so i could fine tune it better Image then cut and drilled one from the aluminum rough cuts came out nice Image Image 3 more to go
back n the garage pulled the gas tank Image drilled some holes for electric fuel pump Image going to sandwitch 2 pieces of aluminum with AN6 fittings Image for fuel pump return line and wires
my table of insperation or as my wife calls the shit table Image Image Image
Love the can of bud, prominently displayed in a few pics.
Can't wait to see the finished product!
yes Raj working on the bug always involves a bud
got my mid engine header today s744.photobucket.com gonna put the turbo in the backseat area Image Image
got some time on the bug Image tapped the gas tank to 1/4 pipe Image and plugged the hole for now Image made the bottom plate to sandwich the electric fuel pump onto the gas tank Image Image i just need to weld some aluminum bolts to the bottom plate and weld a support for the fuel pump
VERY nice! Very custom too!
so Santa was very nice this year Image got mostly everything to get it done
Looking forward it seeing it done!
back on the fuel tank today Image rusted on bad reseal Image so i did old school clean the tank with bbs and ball bearings. Image Image will wash with gas tomorrow and reseal
Nice..... I usually use an old chain. Keep up the good work!
ready for the change from carb to EFI Image
got busy today indexed the crank trigger wheel found this sticky tape measure at Hobby Lobby it help me find the center of the missing tooth Image drilled the holes Image Image tapped the threads Image counter sunkthe bolt holes Image will take it apart tomorrow hit it with some brake clean put locktite on the screws and move foward
