68 Bug
Re: 68 Bug
So i decided to clean up the bug and have been working on the front of it. Here are some pics of it with the front fenders off and the damage found. It's not really that bad at all.
Right side
Re: 68 Bug
This is what it looks like after a little elbow grease.
rust repair
Re: 68 Bug
You didn't do that, there's no blood to be seen.
Re: 68 Bug
nice Ken, What are you use to cut through the undercoating?
Re: 68 Bug
Still a little cold for epoxy Ken. I would wait till is above 50. But I know how it is trying to get stuff done.
Re: 68 Bug
Raj wrote:nice Ken, What are you use to cut through the undercoating?
Nothing sepcial, some of it was loose and scraped right off and then i use thw wire wheel on my angle grinder
Glenn A wrote:Still a little cold for epoxy Ken. I would wait till is above 50. But I know how it is trying to get stuff done.
Thanks, i was not sure!!!i've got some time!!!
Re: 68 Bug
Took some time today to prep the car for replacement of the heater channels. Removed the the seats, remaining carpet (not much), heater tubes under the ream seat and cleaned up the sealing material from the interior around the heater channel welds.
driver side heater tube. Note spot welds which i had to drill out to remove it from the car. No Bakelite connects in this bug.
Passenger Side
here is the spot welds to the heater channel behind the voltage regulator
Passenger side
Front area of heater channels
Re: 68 Bug
Nice Ken. Those channels don't look horrible. It should go smoothly.
Re: 68 Bug
Glenn A wrote:Nice Ken. Those channels don't look horrible. It should go smoothly.
Thanks! I have watched the Bug me video a few times and what it is missing in production quality it makes up for in pictures of exactly what and where to drill and cut. I'm actually excited about doing this as I thought it was going to be a much more difficult job then it seems to be so far.
One PITA is going to be having to disconnect the wire harness in the front to feed it back through the hole in the new heater channel, but I can do that at my leisure or never!! :lol: :lol:
Re: 68 Bug
Brown wrote:
Glenn A wrote:One PITA is going to be having to disconnect the wire harness in the front to feed it back through the hole in the new heater channel, but I can do that at my leisure or never!! :lol: :lol:
I guess you might be able to leave a cable in the new channel to use as a drag at a later date.
Re: 68 Bug
Brown wrote:
The Hole I'm talking about is is very short so feeding the cable through isn't much of a problem. The problem is having to disconnect the cable from the trunk side. See the two pictures above. In the second one i cut the metal to pull the cable out. The top picture is not cut!
Re: 68 Bug
you're not kidding, that is a very small area to feed all those wires through
Re: 68 Bug
good pics Ken. Keep them coming. My baja is a 69, and I bought it as a unfinished project. Whom ever did it left the wire outside the channel. Not too big a deal, just never bothered me to do anything about it when I redid the wiring. The main loom either in these cars or the earlier ones ( where it runs through the roof line) arent fun to replace.
So you going to be 'bug less' for a while or do you still have the rotten banana to drive in the interim?
Re: 68 Bug
Bugless Yes for a little while!!! hoepfully not for too long though!!
Re: 68 Bug
you took the words right out of my mouth Raj, I was gonna ask Ken the same question.
Re: 68 Bug
mannys66 wrote:you took the words right out of my mouth Raj, I was gonna ask Ken the same question.
right?
I can barely keep track of what i'm working on and how long I wont be driving it, much less any other DVG'ers and their cars!
Re: 68 Bug
right?
I hear you brother, it's hard to keep track LOL, you do have a lot of cars.
Re: 68 Bug
Just checked my heater channels are in transit to Uniondale. Hoping for a delivery tomorrow so i can work on the install this weekend!!!
Re: 68 Bug
Delivery Today!!!
Hope to find some time today but if not then tomorrow!
Re: 68 Bug
Who'd you buy them from ? Are they the Danish ones ?
Re: 68 Bug
Tom wrote:Who'd you buy them from ? Are they the Danish ones ?
CiP1.com They are made by Dansk...Danish? Ja
They seem failyr substantial!!
Re: 68 Bug
Nice buy ken. Kelp those pics coming!
Now I'm hungry for Danish. Yum
Re: 68 Bug
Got a little sidetracked today. I've been working on giving the kitchen a little facelift and today was the installation of a new stainless steel sink. Started out well, removing the old cast iron sink (that will be making a trip to the scrap yard). Then the funs started. The opening was too small so i had to grind a little, cut a little then gring somemore befroe i fannly got it to fit. The i had to remove the section of the door becasue i could not get the sink hold down clip installed otherwise. After installing the drain and fixture and setting the sink in place I made my first trip to home depot to get a new drain pipe, seal and some fittings. After getting home and installing the new drain pipe i had to cut back the pvc to move the trap but my PVC glue was all dried out, so one more trip to the depot for glue. FInished up about 7:00 PM
No VW time but at least I'm a ittle close to finishing the kitchen!
Re: 68 Bug
Perty!
Re: 68 Bug
That should be good for a few more weekends working on the VW ;)
Smart move.
