Page 6 of 16
Posted: Sun Aug 07, 2016 5:54 pm
by Big_kid
Making way on this car- keep at it!
Posted: Sun Aug 07, 2016 6:19 pm
by elrockk
got the brakes bleed today using vacuum bleedertook 10 minutes. got the engine wired and runnining, it wont idle though so i think i need to open up the carb must be some Gak in the idle jet.got the gas Imagetank in and welded the pakage tray to those things Image
Posted: Sun Aug 07, 2016 6:33 pm
by elrockk
im looking into getting the drivers seat back in does the seat adjuster lever face the tunnel or the heater channel thanks
Posted: Mon Aug 08, 2016 5:11 am
levers on seat face the channel, not the tunnel.
Posted: Mon Aug 08, 2016 10:45 am
by elrockk
Thanks Raj
Posted: Mon Aug 08, 2016 7:32 pm
by elrockk
pulled the seat from the loft seems they both have the levers on the right side of the seat,but the tracks welded to the floor both have the teeth on the right track Image so i got the rusted mess off of the seat Image put the slides on Image
Posted: Mon Aug 08, 2016 7:43 pm
by elrockk
got the seat installed and drove it into the garage under its own power. brakes Image Image
Posted: Tue Aug 09, 2016 7:44 am
Its getting close!
Posted: Tue Aug 09, 2016 8:20 am
by Tom
Looks good, are you going to replace the tar board or install a different sound deadening product ?
Posted: Sat Aug 13, 2016 6:30 pm
by elrockk
i have the original tar board but forgot toput it in before installing the engine Tom. im sure it will be in and out a few times
Posted: Sat Aug 13, 2016 6:46 pm
by elrockk
got in the garage today mad hot but i got some work done. made this for the L/F inner fender Image welded in patch panel Image Image after cutting out rust Image going with spot welds then weld the edges
Posted: Sat Aug 13, 2016 6:50 pm
by elrockk
not going topay attention to the A pillar at this time,i have replacements for the future Image Image
Posted: Sat Aug 13, 2016 6:59 pm
by elrockk
i have a question if anyone knows. the car wont idle it did idle run when i removed it i see there is an idle air adjustment screw on the left side of the carb does anyone know what the starting point for this would be like 2 turns out or more mine was at 6 turns out i put it to 2 but it still wont idle think i might have a air leak at the intake? also my carb has 2 screws on the left a small one which i think is the idle air screw and a large one that i have no idea what it does
Posted: Sun Aug 14, 2016 10:41 am
by Big_kid
What carb are you running? The 34PICT3 has a solenoid on the left side that needs power or it won't idle.
Posted: Sun Aug 14, 2016 10:58 am
by elrockk
ill check that thanks
Posted: Thu Aug 18, 2016 6:09 pm
by elrockk
i checked that solenoid its working properly, even took my new endoscope for smart phone and looked inside to see all was clear. i found a video on you tube by VW Darren that said to check the idle jet by the choke adjuster and sure enough it was plugged Image so now shes idling on her own Image installed a new air filter Image and a new shifter Image
Posted: Thu Aug 18, 2016 6:12 pm
by elrockk
i adjusted the carb by ear and tommorow ill bring home my tach and do it correctly by rpm
Posted: Thu Aug 18, 2016 10:15 pm
by Big_kid
Kicking ass and taking names- coming together nicely!
Posted: Sat Aug 20, 2016 7:34 pm
by elrockk
first burnout in the driveway looks like its got a posi Image welded the rf to the heater channel Image made a patch piece to fill in the hole Image got it fitted
Posted: Sat Aug 20, 2016 7:38 pm
by elrockk
got it fitted Image and welded in Image Image then ran out of mig gas
Posted: Sat Aug 20, 2016 7:43 pm
by elrockk
so figured why not paint the inner fenders with some rustolyem Image and maybe get the front fenders backon tomorrow Image
Posted: Sun Aug 21, 2016 1:18 am
by B MAN
great work man
keep at it
Posted: Sun Aug 21, 2016 10:21 am
by Big_kid
Runnin' drivin' and smokin' tires! Love it!
Posted: Sat Aug 27, 2016 6:58 pm
by elrockk
got some time today got 2 broken bumper bolts out Image i tried to weld a big nut to the broken bolt but broken bolt 2 gene 0 Image so i went old school and drilled and tapped them out
Posted: Sat Aug 27, 2016 7:03 pm
by elrockk
pretty much finished welding the front patch panels in Image Image and put another coat of rustolium on the inner fenders Image
