Rob's 1977 Fatty Camper
Re: Rob's 1977 Fatty Camper
Nice try, bent cover and lousy gasket. But I win this round
So, 2:30am, 400 miles from home, 350 miles from nc, the camper decides to die. Thankfully Gemma kept me from jumping off a bridge and I figured out the problem. Number 3 spark plug decided to pop out. And when it did it took the temperature sensor with it. Everything's fixed running fine now.... Just entered NC
Define 'popped' out? Was it loose and just backed out, or took the threads with it?
Saw your radio deck set up on fb... when you get back, I was see the deets on it pls. Id like to get some movies going this summer to keep the boys busy if need be.
That trip home is cursed.
Raj wrote:Define 'popped' out? Was it loose and just backed out, or took the threads with it?
It must have backed out. I was able to screw it back in tight. Sure thing on the radio
Did you bring back some ribs and slaw?
2nd time in about 3 months this has happened on the right side. Bad gaskets, or something else to look at? I replaced it today and put a thin bead of sealant behind it to see if that helps any.
Ok, dealt with the oil leak, changed the pop top seal, replaced the headlights (You were right, Mike, the new ones are MUCH better) and replaced the antenna.
Not a bad day at the office.
Only down is one of the cheap plastic headlight rings cracked when I put it back on, so no eye lids until the new chrome ones I ordered come in. I bought the headlights with the little city lights in them. I'll wire those up to the ignition on when I replace the rings
Sigh.
It will be better soon enough.
You going to powder coat the tins ?
No, Tom. Just gonna make it functional again. For the most part I'm done doing anything pretty with this one.
Nice looking distributor ;)
Yah yah .. I got one too! Lol
Rob, what's the plan here? Just top end?
ObnoxiousBlue wrote:Rob, what's the plan here? Just top end?
Looks that way.
Rob , I was kidding . .
Tom wrote:Rob , I was kidding . .
So what, my bus isn't good enough then? :lol:
Tony's gonna clean it up and paint some stuff. Replaced pretty much everything plus the clutch. Saw it today, it's a minor miracle it lasted as long as it did.
I'll make sure to keep my powdered tin's with me, until your engine is reassembled and in your bus! LOL
Tins painted and on, things are coming together. Couple of lonely sage campers in the parking lot.
Bit by bit......
Glad they had a manual handy, since the torque specs on a Type 4 is different than a Type 1.
It's better to refresh your memory than you rely on..... what were we talking about?
Looking good Rob! Glad to see the guys at GT getting some practice in before my engine arrives! Lol
Really though, I'm excited to see it back and runnninf nice and happy. It never ceases to amaze me how in-sync our mechanical failures are/have been through the years. :lol:
Glenn wrote:Glad they had a manual handy, since the torque specs on a Type 4 is different than a Type 1.
Turn the wrench until it cracks then stop :-)
Anyone else find it funny that the manual has a green cover? :mrgreen:
