69 baja
Re: 69 baja
Brown wrote:Did you get it aligned yet?
I have yet to find a reputable alignment shop that can do a non stock VW ( all of my vws). Until one is finally done with proper stance etc, I continue to do the alignment via jack stands and mason twine. So far so good..... no pulling on the road or abnormal wear on the tires.
brucerodz
First Name: Dave
Vehicle Year: 1976
Re: 69 baja
Post by brucerodz »
Not meaning to hijack your thread but, found this little tip for doing ball joints on another vw forum. May be of use later.
http://forum.georgiadubs.com/t7469-inst ... all-joints
I'm drinkin' TNT, smokin' dynamite
Re: 69 baja
Dusting off the fleet after a long cold winter. After I sold that red thing, and popped the rebuilt 1641 in the baja for a year or so. Ran great and had no issues. Bc I cant leave well enough alone and bc Id prefer not leave that motor with its thing only exhaust and tin exposed to the elements, I swapped back in a 1600 dp.
Picked up a set of 4 lug centerline style rims for this, so I may ditch the steel baja style rims that are heavy and rusty. Need to tune the carb this weekend button it up, and add this back to the driver mix.
