69 baja
Re: 69 baja
Sooooo I'm guessing some 3X3's and new rear meats are in order ? NICE ! Once that is done We can get the measurements for the wider lifted beam ! Oh yea and dust off those thing spindles !
Re: 69 baja
glenn a wrote: Oh yea and dust off those thing spindles !
I'd love to rock the thing spindles but I dont know if I can use them with the ghia disk brakes. Its a toss up. I might just invest in lifted BJ spindles for the nose.
Re: 69 baja
So shes on the road. Needs to get an inspection on Sat, from one of ' my boys'. ( no mirrors on it yet... maybe ever)
I have one of Keith ( from TS). Idles great but misses alittle upon throttle. I'm working on that.
Anywho.... I had brand new grey KYB up front on this thing. Too soft.... the nose dives every time I slow down or stop. And then the tries rub. I dont wanna F up the fenders any more than there are. so..... I wen to the parts mahal and located a set of coil over BJ shocks. They are a bit longer too, so it fixes the issue I was having with the greys limiting my downward motion. The adjuster are maxed out on the beam, so this is form the stock stuff.
Re: 69 baja
first dry day in quite some time... wanted to check her out a little. Going for inspection in the AM.
- volksbugusa
Re: 69 baja
Your project really came out very nice.Wheels look great!!!Good luck with it....Hope to see it soon...Matt
Re: 69 baja
volksbugusa wrote:Raj
Thanks bro... come out wed... she'll be out.
Re: 69 baja
Nice Raj, Looks nice with the metal rack on it . I'm waiting for the youtube doughnut videos !
Re: 69 baja
glenn a wrote:Nice Raj, Looks nice with the metal rack on it . I'm waiting for the youtube doughnut videos !
I dont think it can do donuts.... I have another car for that. lol ( as you very well know......!)
Don stopped by today... with his newly rebuilt Keith carb. We played with teh timing, and shes running better. He should make his debut wed.
Re: 69 baja
Love the color and finish on this. Really smooth like a strawberry daquiri, just in time for the summer!Raj wrote:first dry day in quite some time... wanted to check her out a little.
Re: 69 baja
Had a strange noise in the rear the other day. Turns out the rear drum was loose and wouldnt tighten any more because the outer bearing fell apart.
Thanks to a prompt response to a fellow DVGer.... German FAG part arrived the next day.
New seal
Brakes came apart and went back together real easy since they were all only 3 months old.
Took her for a drive.... much better!
New seal
Re: 69 baja
Yah Yah... I was there when it was delivered...Heard the line already... lolRaj wrote: Thanks to a prompt response to a fellow DVGer.... German FAG part arrived the next day.
Re: 69 baja
What line? I dont get it Mike? You like bearings..... or something.
- volksbugusa
Re: 69 baja
That is a fun repair....but at least it is not a swing axel
nice and dry....did you also replace the other side?
Re: 69 baja
That is a fun repair....but at least it is not a swing axelnice and dry....did you also replace the other side?
nope. Normally I would, but I plan on upgrading the suspension to 3 x3 rear arms eventually, so I 'll replace them all when I do that. Time to too precious right now to be dicking around, and the focus is the 65.
Re: 69 baja
I fixed it for You !Raj wrote: I plan on upgrading the suspension to 3 x3 rear arms very soon !
Re: 69 baja
Did this little project last week or so.
Off with the old, on with the other old one. I'll run this exhaust until the tri mil stinger arrives.
Re: 69 baja
The other morning I tossed this bad boy in.
******WARNING - NOT FOR THE VW PURIST*****
Re: 69 baja
slapped on more baja stuffs. These also make great steps to help you get your cooler off the roof rack.
Re: 69 baja
Let's see some pics of it in the dirt.
Re: 69 baja
Took her for a ride this am to OBI. No problems. I was surprised... she did well.
Got home at 930 am and changed the oil while she was hot. Went to pull it in the street.... and it stalled. Fired again... stalled. Weird. The number 2 rule for a ACVW should be, that if it stalls... dont restart it. Check the fuel hoses first. Why, you ask... bc when they fall off or fail... it usually results in fire. Well.... mine fell off in my route from my drive way to the street. Very odd.... and I'm very thankful the big guy was watching me at that point. If it would have happened any of the 30 mile before.... instant fire.
Changed the filter, and the hoses..... good to go. whew.
Re: 69 baja
Re: 69 baja
no braided hoses GR?
- volksbugusa
Re: 69 baja
glenn
i like the wire lead for safety.
