Posts: 1029 Joined: Fri Oct 17, 2008 8:09 pm
Post
by AoT » Tue Apr 21, 2009 10:00 pm
Glenn wrote:
MICE ... I hate mice.
(Maybe Manny's friend Pepe camped out here in his younger days.)
Wow, a picture is worth a thousand words!! Glad you think this one has some charm!!
The gauntlet has been thrown down and the challenge has begun. Looking forward to working with the talented brains behind the madness to bring this engine back to life. Time to saddle up and get this wagon train rolling!! Thanks to all for your support, past, present and future!
Posts: 3214 Joined: Tue Sep 09, 2008 4:20 pm
Post
by Glenn » Wed Apr 22, 2009 5:39 am
glenn a wrote: I have a dog house I got from Ken along with tins. I'll bring them incase Jim can't make it .
Bring it since i doubt Jim cam make the meeting. He usually has Cub Scouts on Wednesdays.
I'm gonna try to bring the alternator over to GT. Tony is going to have it checked.
Posts: 1050 Joined: Sun Sep 14, 2008 12:02 pm
Post
by Tom » Wed Apr 22, 2009 9:58 am
The starter looks new...
Brown wrote: Tom is right!
Posts: 1424 Joined: Tue Sep 09, 2008 5:23 pm
Post
by ObnoxiousBlue » Wed Apr 22, 2009 10:31 am
Tom thats one of Glenns. Its attatched to a sawed off bellhousing so that he can ground start motors. It bolts on and off and he can spin the motors up without having them in a car.
Post
by AoT » Wed Apr 22, 2009 12:03 pm
What goes around, comes around. I remember when you gave me this list. Now it's back on mine!
The beauty of recycling VW parts!
Post
by Glenn » Wed Apr 22, 2009 8:50 pm
I got a fan shroud from GA from Ken and a crank pulley from Raj.
If anyone has a set of good solid upper cylinder tins let me know. if not we can reuse the old ones.
Posts: 385 Joined: Tue Sep 09, 2008 8:20 pm
Post
by Glenn A » Wed Apr 22, 2009 9:03 pm
Glenn wrote: I got a fan shroud from GA from Ken and a crank pulley from Raj.
Will tins from a 40hp work ? I have tins on a motor that came out of a 64 .
Post
by Glenn » Wed Apr 22, 2009 9:09 pm
No... they have to be 1600DP tins. The old ones will do, they are just a bit flimsy.
Posts: 75 Joined: Wed Sep 10, 2008 4:03 am
Post
by volksbugusa » Thu Apr 23, 2009 3:51 am
looking really good....if you apply pur 15 to the tins the product will help try at least two coats....
....Glenn before I install my motor I would love to borrow your starter set up to check things out....
uBerStehle
Posts: 8 Joined: Wed Sep 10, 2008 10:36 am
Post
by uBerStehle » Thu Apr 23, 2009 8:22 am
Glenn wrote: MICE ... I hate mice.
Good thing you guys decided to remove the fan housing. With that much crap in there if the engine fired up I'm sure it would have self-destructed in short order!
Remember, wherever you are - YOU ARE ALWAYS HERE!
ROB
Post
by Glenn » Thu Apr 23, 2009 12:15 pm
So I did a valve adjustment and checked compression.
50 - 100 - 50 - 30
Not good... I sprayed some PB Blaster in the cylinders and cranked it for 30 seconds. I'll repeat after a few hours and recheck.
I hope it "pumps up", or it's Plan D.
Post
by AoT » Thu Apr 23, 2009 12:46 pm
Glenn wrote: So I did a valve adjustment and checked compression.
50 - 100 - 50 - 30
I'm "wondering" if this is ever going to be a 'wonder' or a worry!
Should I put it on the organ donor list?
Posts: 1937 Joined: Tue Sep 09, 2008 8:03 pm
Post
by Raj » Thu Apr 23, 2009 1:45 pm
50 - 100 - 50 - 30
at this point why dont we just replace the rings at a minimum, or if we have to P and C's, maybe a valve job while the heads are off.
Glenn wrote: I have to say, this "gruppe" is so much more than just a car club.
MrBreeze wrote:
This is the DVG board. The threads flow as they flow.
Post
by Glenn » Thu Apr 23, 2009 1:58 pm
Taking this engine apart is a can of worms.
All the exhaust studs look badly rusted and the odds are most of them will break. The head studs are also rusted and might be a problem. And who's to say the valves are not the problem. So to do pistons, cylinders and heads you're looking at $500 in parts.
GA still has his engine, but i'm thinking of getting this one started and checking compression when its warm.
Post
by Glenn » Thu Apr 23, 2009 5:10 pm
It runs....
http://www.youtube.com/watch?v=pMtiPtQ6ZJw
But not very good. After letting it get hot, i remove the plugs and checked compression again. Not much better.
75 - 125 - 70 - 40
Time for Plan D.
Post
by Big_kid » Thu Apr 23, 2009 6:04 pm
Ouch.
Not valves? Try some seafoam?
Post
by ObnoxiousBlue » Thu Apr 23, 2009 6:42 pm
Wow. Sorry AoT, its nice to see someone has the same shit luck as me! LOL
Now, what IS plan D?
Post
by Glenn » Thu Apr 23, 2009 7:38 pm
Big_kid wrote: Ouch.
I already tried some PB Blaster and cranked it for 30 seconds. Then let it site for a few hours and applied more. I then checked the compression and it was barely better. Tony suggested running it until it gets hot but he doubts it would help... it did not.
Short of a top end rebuild, this not not going to move a car.
Plan D is a engine that Glenn A has.
Post
by AoT » Thu Apr 23, 2009 7:52 pm
ObnoxiousBlue wrote: Wow. Sorry AoT, its nice to see someone has the same shit luck as me! LOL
this is what I posted under '74 Gigggles in (Tech Discusions) a few weeks back:
Ok. You have been warned that any projects that I participate in have a tendency to have lots of bumps in the road so just be prepared to giggle as we move forward. I won't be offended as you roll over in laughter when you see what greets me on a good day!
And believe me when I read your post I got a good laugh!!
Move over Mike, make room for me!!
Post
by AoT » Thu Apr 23, 2009 8:00 pm
Glad we have a plan D! How far along in the alphabet is this going to take?
"'A" didn't work and it better not be "T'"!!
I am on a giggle high!!
Better laughing than the alternative.
Post
by Glenn » Thu Apr 23, 2009 8:20 pm
All in a days work.
The good new is the alternator is good, I have most of the tin, the carb on that engine is OK and so is the fuel pump.
Post
by Glenn A » Thu Apr 23, 2009 8:40 pm
Say hello to plan "D"
Post
by Glenn » Thu Apr 23, 2009 8:48 pm
Looks like a plan.
Post
by AoT » Thu Apr 23, 2009 10:13 pm
glenn a wrote: Say hello to plan "D"
I'm speechless! that's one bad a$$ looking engine! SWEET
Post
by ObnoxiousBlue » Thu Apr 23, 2009 10:28 pm
Well, true to luck, plan D is no prettier than A, B, or C! LOL
