Rob's 1977 Fatty Camper
Re: Rob's 1977 Fatty Camper
Postby Raj » Tue May 22, 2018 2:45 pm
MrBreeze wrote:Always the last bolt. New cable is in but the top bolt on the bowden tube bracket is stripped. Ordered a step down stud and I'll be back under the bus on Saturday. Nice to be getting my hands dirty again, been a long time.
always feels good my friend..... good for you!
Postby MrBreeze » Fri May 25, 2018 7:53 pm
Ok, tapped it out, put the stepdown bolt in and it all seems to be working great.
Came inside and my tv stopped showing video. Gotta give one to get one, I guess :-)
Postby Glenn » Fri May 25, 2018 8:06 pm
MrBreeze wrote:Ok, tapped it out, put the stepdown bolt in and it all seems to be working great.
Don't buy one until you measure the wall space at the house.
May i suggest... "The Wall". 146" (and they say size doesn't matter".
iRide4Sue.org Please Donate to fight Cancer. $26,000 raised in 2019
Postby MrBreeze » Fri May 25, 2018 8:33 pm
Left it off for an hour and it's working now. I don't have much faith in it, this will be my garage tv, I think. We'll buy a bigger one at some point for the living room over the fireplace.
Postby MrBreeze » Tue May 29, 2018 5:52 pm
Well, dang. Alternator is on it's way out. Starting to hear a slight whine from it. I was hoping it was a loose belt, but no such luck. Ordered a new one and I'll put it in before Terryville. Shouldn't be an issue this weekend, it's barely making noise, it just annoys me and I want to stay on top of it. Might as well replace the belt while I'm at it.
Postby MrBreeze » Tue May 29, 2018 5:53 pm
Oh yeah, TV pooped the bed the following day. Got me a big ol' 65". I'm thinking probably the last big ticket item for a while!
Postby AoT » Thu May 31, 2018 9:46 pm
MrBreeze wrote: I'm thinking probably the last big ticket item for a while!
If it is you're only lucky dude.
Postby Glenn » Fri Jun 01, 2018 4:45 am
Rookie home owners... gotta love them.
BTW, Toby is closing on his today.
Postby MrBreeze » Sun Sep 02, 2018 10:34 am
https://youtu.be/muxPQOXyxIM
Anyone happen to have a smoke machine?
Postby Glenn » Sun Sep 02, 2018 12:24 pm
I might have a old bong laying around.
Postby BusBq Bill » Sun Sep 02, 2018 4:29 pm
Yes i have a smoke machine .. "smoke pro" you are welcome to borrow it, However I do use it so i have a one week free rental policy.. I have your extention cord still sorry .lol if you want to borrow it text or call me 5166984066
Postby Tom » Mon Sep 03, 2018 8:39 am
Glenn wrote:I might have a old bong laying around.
Dibs !
Postby MrBreeze » Mon Sep 03, 2018 9:27 am
Thanks Bill, I'll call you Friday. My plans for looking at it today are shot. Slipped off the deck yesterday and turned my ankle. Taking it slow today.
Postby ObnoxiousBlue » Tue Sep 04, 2018 9:07 am
Rob, I had that same whistle. It was my S boot.
Postby MrBreeze » Tue Sep 04, 2018 3:17 pm
ObnoxiousBlue wrote:Rob, I had that same whistle. It was my S boot.
I'll check it out
Postby ObnoxiousBlue » Wed Sep 05, 2018 9:29 am
They tend to crack along the ribs, so you may not see it immediately. Mine was held back together with RTV.
The new boots that they make are garbage. There was a company out there using a rubber/plastic that was similar to original, but less prone to cracking. I believe AirHead Parts had been a distributor for a while, but their site does not list it any longer and I would have to look back for the manufacturer since there are several.
I went with the GeeBee hoses. They'te the "one and done" option if you don't want to fight with it again. Below is an excerpt from my hose issues in my bus' thread.
Postby MrBreeze » Wed Sep 05, 2018 7:06 pm
Ok, not the S-Boot. Took it off completely and while I obviously couldn't run it, I still heard the squeal while cranking it. So I'll smoke the sumbitch this weekend and go from there. If I can't figure it out I'll drive it squeal and all to Flanders and see if the boys can help figure it out. If I can't get it going right soon, I'm probably done for the year, no Salem.
I'm learning the joys of home ownership, especially with 79 and 82 year olds living with me. One of them let the puppy get out the front door and she bolted down the street. Thankfully the mailman grabbed her. So today I ordered the dog gate. Seems every day I'm solving some sort of problem. It could be worse, my little brother got his house a week after mine and he's stuck with $8,000 in mold damage he got screwed over with.
All in all, I'm still digging it.
Postby MrBreeze » Mon Sep 10, 2018 12:11 pm
Well the smoke test didn't show anything. So I guess I'll just drive it as is to Flanders and see if anybody has an idea there.
Postby Tom » Mon Sep 10, 2018 1:21 pm
Does it run any different ? Or is it just a noise issue ?
Postby MrBreeze » Mon Sep 10, 2018 3:09 pm
Well it was running really bad, bucking, practically stalling, but it seems to be running pretty good now. I'm wondering if I had bad gas, it seems ok since I last filled it. I'm not sure if the noise is affecting it, but it sure is annoying as hell.
Postby MrBreeze » Thu Nov 08, 2018 3:31 pm
Looks like the bucking problem is solved. It was the AFM. The track the needle rides on was grooved, so moved it a little to a clean track and now it's running great.
Still has that squeal once in a while that I can't find.
Postby Glenn » Thu Nov 08, 2018 4:05 pm
MrBreeze wrote:Still has that squeal once in a while that I can't find.
You need more lube.
Previous
Return to Weekend Warriors
Users browsing this forum: No registered users and 1 guest
