1991 Volkswagen Vanagon GL 145,000 miles
Last Model Year of 3rd Generation Bus Runs and Drives Excellent. Lots of Power. Handles Great. Needs Nothing.
Original Power Mirrors (They Work!).
Engine rebuilt to 2.2 liter using Mahle Big Bore 96mm Pistons and Cylinders at 136000 miles
Oil Changes every 2500 miles with Brad Penn (The Green Oil) and Mann or Mahle Filters.
Manual Trans Re-Sealed at 127000 miles
P/S System Flushed and New Fluid 142000 miles
New Injectors and seals
Upgraded to 15" Wheels and Nokian WRG3 All Weather Tires with Correct Load Rating
Go Westy High Power Headlamp and Relay Kit with Higher Wattage Bulbs
Fuel Tank Reseal with all new Fuel Lines
LED Dash and Interior Lighting
8 Speaker Sound System
Replaced P/S Pump, Water Pump, Alternator,Battery
All Coolant hoses and lines replaced in Engine Compartment
Replaced A/C Compressor, Receiver Dryer, Expansion Valve, Evac and recharge RedTek 12a conversion
New Complete Digifant Computer Wiring Harness from Kyle Automotive Specialties
Replaced Power Steering lines complete with Parker Heavy Duty P/S Hoses from front to rear from Bus Depot
New Distributor, Air Flow Meter, Idle Control Module
Ignition wires, Plugs, Fuel Filter, Air Filter
New Clutch, Pressure Plate, Throw out Bearing, Flywheel, and Slave Cylinder
VDO Oil Pressure Gauge Installed
Front end rebuilt including Ball joints, Upper/Lower Control Arm bushings
And Much More
Original Survivor! Have Extensive Paperwork History. Original Paint and Interior. Paint Has Fade on Roof and a few small Blemishes. Had some rust repair done around rear window by previous owner.
Original Owners Manual, Manual for Pioneer Stereo,Many Extras to Go With Bus
Pics can be viewed at: https://longisland.craigslist.org/cto/6064864522.html
Asking 9500.00 Call Jimmy: 631 897-6943
