1977 Westfalia
Re: 1977 Westfalia
Postby MrBreeze » Tue Jul 14, 2015 1:40 pm
Good info in that thread. I ordered the washers they were talking about. Bag of 100, I'll have plenty if anyone needs.
Now I have to find that double washer that connects every 2 bolts, there were none on mine, I never knew they had them. Also ordered new bolts from BD.
Re: 1977 Westfalia
Postby Tom » Tue Jul 14, 2015 1:44 pm
MrBreeze wrote:Good info in that thread. I ordered the washers they were talking about. Bag of 100, I'll have plenty if anyone needs.
They most likely fell off.
Re: 1977 Westfalia
Postby Tom » Fri Nov 13, 2015 3:19 pm
Hey Rob, which washers did you order ? I did the CV boot on the passenger side last winter and I was under the bus last week and saw the drivers side is ripped. :roll: This is a messy job that I don't look forward to.
Re: 1977 Westfalia
Postby MrBreeze » Fri Nov 13, 2015 7:35 pm
Re: 1977 Westfalia
Postby Tom » Sat Nov 14, 2015 7:35 pm
Thanks Rob.
Re: 1977 Westfalia
Postby MrBreeze » Wed Mar 01, 2017 8:36 am
Well, it's that time I guess.
After checking out the spark plug hole it's been decided that head is fubar. So new heads it is. Got the heads off, let's deal with that sticky lifter. Might as well check out the pistons, etc as well. So probably a top rebuild is in the cards. Might as well change the exhaust too.
Fu#k. Didn't plan on this. But, that's the way it usually happens. So hopefully it'll be ready for the start of camp/show season.
Mike, what exhaust did you go with? Are you happy with it?
Re: 1977 Westfalia
Postby Raj » Wed Mar 01, 2017 5:18 pm
Rob,
You doing this yourself or subbin' it out?
Previous
Return to Garage Space
Users browsing this forum: No registered users and 2 guests
