Postby elrockk » Tue Aug 08, 2017 8:43 pm
found site postimg.org seems better/easier then photo bucket. so i changed my fuel pump 2 weeks ago Image and figured id change the oil Image and while changing the oil i found my oil leak [url=https://postimg.org/image/4a1d4zrah/Image[/url] so i think ill try torqueing the heads /resetting the valve adjustment and dropping the timing and redoing the carb adjustment
Postby Tom » Wed Aug 09, 2017 5:57 am
Are you going to torque the heads for a reason or just S and G's ?
Be aware that the head bolts are known to pull out of the cases on these old motors then you are in a world of hurt. Ask me how I know ...
Postby Tom » Wed Aug 09, 2017 8:59 am
elrockk wrote:Does anyone here have a SUGARGLIDER or know someone that does . I have some Free stuff like a climbing tower /food /snacks and vitamins if anyone wants
https://longisland.craigslist.org/zip/d ... 59369.html
I have to admit I had no idea what this was until I saw it this morning.
Postby elrockk » Wed Aug 09, 2017 4:54 pm
im torqueing the heads because that seems to be my oil leak from the base of the jugs. i think its only 20 something foot pounds
yes that s the stuff im giving away Image had to put my buddy down and would like to hook someone up
Postby Tom » Thu Aug 10, 2017 10:47 am
Okay, didn't know that was you.
If it is leaking from the base of the jugs I doubt that tightening will stop it, the sealer is compromised between the jugs and the case. (Permagasket type sealer) As I said before unless it's a hideous leak I don't think I would risk it but that's just me because when I tried to fix my leak I ended up buying a motor. :oops:
Postby elrockk » Thu Aug 10, 2017 9:52 pm
i think 23 foot pounds should not break anything but i will eat crow if it does. ive also read that loose head bolts let the jugs go up and down and pound the case leading to engine damage. 23 foot pounds or bust
Postby elrockk » Thu Aug 10, 2017 9:56 pm
i just did an engine at work was 59 foot pounds plus 90 degrees then plus 60 degrees came out to 245 torque total
Postby Tom » Fri Aug 11, 2017 6:21 am
elrockk wrote:i just did an engine at work was 59 foot pounds plus 90 degrees then plus 60 degrees came out to 245 torque total
Was the case made of magnesium ? :D
Postby elrockk » Sun Sep 10, 2017 7:04 pm
got some time in on the bug gonna start and finish each corner one at a time Image Image Image Image got the new quarter panel and body tweeked to fit nicely hopefully more work this week
Postby elrockk » Sat Oct 14, 2017 6:17 pm
got some time in the garage today Image cut out the old quarter panel Image sanded drilled and punched wholes for spot welds Image and got a pretty good rough fit Image
Postby elrockk » Sat Oct 14, 2017 6:20 pm
i need to do some repairs to the infrastructure that the quarter panel welds to and fine tune the fit and spray some of the infrastructure with rust incapsulator while i have the panel off
Postby elrockk » Sun Oct 22, 2017 5:18 pm
i got the new quarter panel tacked in today Image Image Image
Postby Big_kid » Sun Oct 22, 2017 7:15 pm
Nice work! Keep at it!
Postby elrockk » Tue Oct 24, 2017 7:20 pm
picked this up on ebay Image its for way down the line but the price was right. hopeing to get mexican fuel injection hard parts for xmas
Postby Glenn » Tue Oct 24, 2017 7:28 pm
Funny looking hair dryer.
iRide4Sue.org Please Donate to fight Cancer. $27,000 raised in 2017
Postby elrockk » Wed Oct 25, 2017 5:52 pm
i havent needed a hair dryer for some time now
Postby Tom » Wed Oct 25, 2017 8:20 pm
elrockk wrote:i havent needed a hair dryer for some time now
As Bill Clinton would say " I feel your pain." :D
Postby Glenn » Wed Oct 25, 2017 9:26 pm
As Bill Clinton would say "I didn't have sex with that hair dryer"
Fixed for you.
Postby elrockk » Fri Nov 17, 2017 10:03 pm
photobucket fix worked on my thread Photobucket Hotlink Fix use at your own risk i havent been able to scan it for viri
Postby elrockk » Sat Dec 02, 2017 8:16 pm
more parts for fuel injecting the bug Image Image Image Image got fuel rail with 6 injectors and wiring for 50 bucks shipped. got throttle body with map/tps/iac/and a vacuum switch with wiring for 25 bucks shipped waiting on cb intakes for xmas
Postby elrockk » Thu Dec 07, 2017 10:13 pm
more parts to fuel inject the bug Image
Postby elrockk » Sat Dec 09, 2017 9:15 pm
layout to start making the intake Image Image
Postby elrockk » Sun Dec 17, 2017 7:25 pm
got some time today and cut out the end of the intake that will bolt to the throttle body Image
Postby Big_kid » Sun Dec 17, 2017 8:34 pm
I wish I could keep up with your progress! My Astro van is kicking my butt these days.
Postby elrockk » Mon Dec 18, 2017 7:28 pm
yeah my daily has been nickel and dimeing me the last 3 months
PreviousNext
Return to Garage Space
Users browsing this forum: No registered users and 3 guests
