Bunch of late model beetle parts and other stuff for sale
Post your Volkswagen, or parts FOR SALE here.
Postby LessThanJake on Mon Feb 08, 2010 3:18 pm
Front fenders for 1968 and later beetle.
good condition, No dents, No Bondo, passenger side one has a small rust hole in the headlight bucket
(not visable once the light is installed) which I can repair for an extra $20.
$75 for the pair obo.
rear decklid for 1968 and later beetle. has the four sets of vents which means its correct for a 1973 and later
but will fit on any beetle '68 and later. (extra cooling!!)
last I check this thing was near mint.
$50 obo.
1973 and later beetle tail light lens's....the big ones that take up half the fender.
decent condition but not perfect. (good spare for your daily driver!)
$10.
1968 and later push button front hood handle and latch, very good condtion. $40
1968 and later convertable beetle doors.
bottoms are rusty.
I'm PROBABLY going to skin them as I need sheet metal for my car...but I'll be persuaded by offers, so make one
if your interested :)
Rear apron for 1968 and later beetle, good shape but has one minor dent thats easyly fixed. $30
nose clip from 1968 and later beetle. a little rust but nothing too severe. I belive its long enough to
'un baja' a beetle and deff long enough to repair a front end collison. $45
super beetle glove box. black and fuzzy. has compartments and hood latch lock thing, near mint. $15
1200 short block, cylinder heads, crank, pistons, etc, all inside and untouched.
MOST LIKELY will need to be rebuilt. $120
vent thing....I have no idea what it is, its a pipe with another pipe attached to it and it has
vents on one of the pipe things and the whole thing looks like a Plus sign ( + ) I belive its to
an eary bus? $5
rear door off an older chevy van. has a window. its white. its mint. its also white. $20.
drivers side door off an older chevy van. its a door. its got windows, its in good shape, $20.
16" 'hot rod' bike, built from a 20" schwinn, its black with green and white flames, purple stripes on the back
and really cool purple metalic handle bar grips and seat. $120.
16" fancy lowrider. buit from a 20" girls schwinn, its extended way out in the middle, sheet metaled in.
beutifal bike,though a little hard to ride due to gear ratio.
I spent something like 3 months building it and put $450 into it but I'll take $250 obo.
20" and 16" 3 wheel bicycle thing, its really crazy, two 16" front wheels, a 20" rear wheel, to pedal you
actually step up and down on two platforms...crazyness! $85 takes it.
apc mini chopper, beat up and customized....runs but not well, custom exhagust, very very loud.
result of boredum. $50 obo
1960's snowblowa', no engine, surface rust, has that really sick looking rotory blade and burrows a hole
through the snow. (tunnles!) I belive its a sears. it worked great before the engine stopped running.
Make an offer?
K2 roller blades, size 12 or 13 I belive?? no bearings, great shape, $20 (there real expensive new)
acetylene sodering (and brazing?) kit, sealed in package: $120 ($160 new, its still sealed in the package!)
6 volt genorator, with fan with electric reducer box $30
stock 6volt genorator stand, good shape, $20
back seat bar thing (the thing that keeps the back seat bottom from sliding foward)
ivory color, looks great $20
pair of rear decklid hindes, decent shape, I belive they came off an oval if that matters to anyone: $20
steel brake fluid botte (vintage!), $10
front hood locking mechanism, I belive its off an oval, ok condition, $15
rectangular peice of sheet meal with a large X brace stamped in it plus what I belive is one old front hood hindge, $5 for the pair.
late model liecense plate light, plastic one with ridges, usuable shape, $10
pair of 1964-1967 beetle turn signal chrome tops, ok condition, good for a driver or a 'rod, $10
one ok condition 1964-1967 turn signal lens $5
6volt coil, might work? I dont know, $5
super beetle dash vents, the two round ones and a square one plus the ashtray: $10.
trailer, its a box, great for hauling stuff home for or to the swap meet, it has two wheels, $150, come get it!!!
late 1970's - early 1980's mongoose bmx bike, really light, chrome still in good shape, old school crank and pedals, just needs rims, which I might have, I was told it was worth $250 so I'll be fair and ask $150obo
1965 steel sliding sunroof volkswagen beetle, fairly solid car but rough, needs: heater channels, rear passenger side floor pan patched (pans are still solid otherwise!), spare tire well replaced, full brake job and a fair ammount of body work...it doesnt currently run but it can and also drove a few years ago. I belive it has a salvage title.The doors still open and close great. and if I had a garage this car would be on the road, but I don't. $800.
to sum it up, if you did the brakes, got it running again and fixed a couple very small wiring issuses, you would easyly have a driveable, but kind of ugly, beetle in about a days time.
"american camper" skateboard, still sealed in the packaging, $15.
LASER DISCS!!! (the 'dvd' of the late 1980s - mid 1990s)
we haaave: "highlander", "blue velvet", "dances with wolves(expanded editon!!)" and "true romance" all for $10!!
I'm 19 and I need money to get my car on the road, every little bit helps!!! :)
trades also are considered for 1966 and older beetle parts
LessThanJake
Re: Giant Pile Stuff For Sale!!!!
Postby Glenn A on Mon Feb 08, 2010 11:45 pm
Could you describe ethe trailer? size? open or closed? homebuilt? brand? papers? roadworthy? lights?
Nicky wrote:"only cool guys drive old VW's, anybody can have a new one."
PREMIUM MEMBER 2010
Postby dano on Tue Feb 09, 2010 11:14 am
Any gas powered generators or air compressors for sale?
dano
Postby LessThanJake on Tue Feb 09, 2010 12:53 pm
the trailer is partly home built, its based on a grainger trailer I belive (my dad built it a few years back) and has about 4' high wood sides and a steel frame with steel mesh on it on the front and back end of it (the back one swings open and can be locked) it has a wooden floor, it has tail lights and I THINK my mom has the title for it. it comes with a dolly that attaches to the front tounge so you can move it around without a car or truck if you want to. its pretty much ready to go, the tires are even still good. I'd guess its around 8 or 10 foot long? and probably about 4' or 5' foot wide? thats just a guess though, I could mesure if for you if you'd like.
Its a nice trailer, it looks like something you could buy, it could use new paint though.
dano: I dont think so but I will check for you. need anything else? theres still tons of stuff around here I havent added to the list yet.
LessThanJake
Postby LessThanJake on Fri Feb 12, 2010 5:09 pm
Here are a couple pics of the bikes that are for sale:
LessThanJake
Return to For Sale
Users browsing this forum: No registered users and 1 guest
